odd speedo issue
avatar28
Nashville, TN
I was on the way home from Atlanta yesterday and encountered a wired issue with the speedo in my 95. The needle started bouncing back and forth about 5 mph and is reading around 5 mph off. The problem was worse around 80. Eventually I got a weird rattling/grinding noise coming from the instrument cluster and the speed indicated would jump 15-20 mph higher. A sharp tap on the face of the cluster caused it to settle back down for a while. This doesn't exactly seem to match the cable issue that seems so common. I'm guessing maybe something to do worth the gears of the cluster?
I think you need a new speedo gauge. I'm thinking the little bearings that the magnet asm rides on are worn out and causing that to rattle around and make noise etc.
avatar28
Nashville, TN
So I need to replace the whole cluster or is that available separately?
Irish Pride
Irish Inside
MusicCityUSA
You need a new speedo. It can be replaced separate or you can replace the entire cluster. My 91 had the same problem. It got worse the faster I drove. Eventually it would read 15mph higher than it was and I had the same buzzing coming from inside the cluster. I used the opportunity to swap in a 6 digit cluster.
