Mike93
Go Sabres!!!
A few weeks back I pulled the engine and transmission to do a handful of maintenance; one of those items was to swap a newer mtx transmission in since the one I had in there had seen better days. The 'newer' trans came from a friend and works great and all, but the problem comes from whenever I use reverse and go to put the car into first gear. Basically when I do this the car will act as if it is in neutral. If I go from reverse to second the car moves forward normally. If I go from reverse to neutral and begin to let the clutch out the car will act like it is still in reverse. One thing that I had to do was reinstall a bolt into the trans that is located near the fill plug. Apparently this bolt has something to do with neutral and reverse...I simply tightened it down, is there a torque spec on this??? Is this bolt related to my issue??? If I remove that bolt I cannot use reverse gear...it acts like it is in neutral.
So: summary.
If going from reverse gear to first gear; car acts like it is neutral.
If going from reverse gear to second gear; car acts normal
If going from reverse gear to neutral gear; clutch engages and car acts as if it's in reverse gear.
If I start the car in first gear and let clutch out; all is good.
If I start the car in reverse gear and let clutch out; all is good. The problem comes from engaging first gear from reverse.
Thanks
So: summary.
Thanks
Oops...
