Occasional hard starting
EMB2580
Mike is a L O S E R
Zion, Il
I am having a problme with my car, sometimes it doesn't start on the first try. It seems to only do it when it's warm. I'm thinking it's the IAC valve. My question, can I clean it and see it that will help any? Also, it looks like a ***** to remove that thing, how hard is it to remove?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
What EXACTLY does it do? Crank slowly? Crank fast? Take a long time to fire?
Easy to troubleshoot the IAC valve during hard starts.
Depress the throttle pedal slightly duriung cranking if you have a hardstart symptom. If the motor fires right away, the IAC is suspect. If not, look elsewhere.
EMB2580
Mike is a L O S E R
Zion, Il
Takes a while to fire. Pressing the gas while starting doesn't seem to help.
1993MTXSHO
Its a Taurus...
Jersey
my car does that in the winter if i start it up and dont give it enough time to warm up. It wil lstall on me and then not start bcak up unless i let it sit for a minute. I never foudn the problem mayeb its something the cars do. could just be lack of maintence in your case, do you know the maintence history, maybe it needs a 60k?:thumb:
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
As mentioned already, check the EEC codes
Well, that is 1/3 of the equation. Air.
All you have left is Fuel and Spark.
The next step I would take would be to check the fuel pressure at the rails.
Also, how old are the plugs and wires?
EMB2580
Mike is a L O S E R
Zion, Il
I have no idea of any of the previous maintence, but I don't have oil in my plug wells, the engine runs like butter when I'm driving, no hesitation, or sputtering, so the plugs should still be good plus it has Motorcraft wires.
I suppose it needs a front? 60k, thats water pump and timing belt and stuff right?
A Robberstad
SHOser EH!
Calgary Alberta
Had a similar problem that eventually got worse (89MTX). I had to replace the dis ignition module which improved the stalling while running, the camshaft position sensor which made it better still. It wasn't untill I replaced the crank sensor that the problem seemed to subside (hard starts and the water pump is fine). It still has hard starts occasionally but only when I can hear a whine coming from behind the back seat which would likely be the fuel pump. At the moment it happens rarely enough that it's not a real issue.
