"O" rings and seals for injectors
rangerj
Brunswick, Ohio
Does anyone have, or know of, a source for "seal kits" for the fuel injectors for the Gen I 3.0L.
Per the Ford computer, at a local dealership, the kits are no longer available. None of the local parts stores could find a kit with anything but the top "O" ring.
The injector is made by "Denso",( as in Nippondenso ?), and is #95500-1960. The subject vehicle is a 1990 SHO with 3.0 liter Yamaha.
As a personal preference, I do not like to reuse a gasket or seal. Thanks, rangerj
The seal/insulator from the injector to the heads? The only way to get these I believe is in the Ford upper gasket set. Unless someone bought one and didn't use theirs. I know Scott found some a while ago but not sure if it was found solo or part of someone's kit.
I bought the square sectioned seals that fit between the injectors and the heads from a member of this Forum. They were part of the injector seal kit. If you are removing the fuel rails and injectors from the heads, these seals are the only ones required. Only if you are removing the injectors from the fuel rails will you need the upper O-rings.
rangerj
Brunswick, Ohio
Update re injector seal kits;
I found the "Injector Nozzle to Head Seals" at SHO-Nut. The kit is a package of 6 seals for the injector-to-head seal. The OEM part number is E9DZ-9C991-A, and the price is $10.21 plus S&H.
The injector-to-fuel rail "O" rings are available as aftermarket parts through "parts" stores. I found mine at a Car Quest.
Thanks for all your responses, rangerj
