o/d light flashing
SHOMON
95 MTX
MEDWAY MASS.
does anyone know why or what for that matter it means when the overdrive light flashes?when it happened itried pressing the switch, nothing.then the car sat and when i left for work it was fine .the tranny is shifting fine so i don't think its a big deal or is it? thanks
Shotime1979 said:
It's telling you it has a problem. It should flash codes IIRC.
Pull the codes just as if you had a CEL. Same procedure, just look for codes in the 700s.
The flashing O/D light means the computer has detected an operating parameter that is out of tolerance. Untill you have a fault code, it is pretty unlikely that anyone will accurately guess what might be wrong.
