Nut size
SHOVNST
Blood type: SHO+
Niwot, CO
On a `92 with factory exhaust I need to know the nut size for the clamp that holds the back exhaust section to the resonator piece.
:thankyou:
Off Road SHO
Moderator
Don't know the size but I have tons of them here. Is this your old exhaust here? Why didn't you cut it up?
Tom
SHOVNST
Blood type: SHO+
Niwot, CO
Anybody have an idea? Or know if they are standard or metric? Anything will help at this point.
SHOVNST
Blood type: SHO+
Niwot, CO
No. This clamp is just after the resonator. This clamp holds the resonator section to the rear exhaust section. After the y-pipe spring bolts this is the only clamp on the entire system.
SHOVNST
Blood type: SHO+
Niwot, CO
This picture gives you an idea where the clamp is located, look at the very top. The resonator section is missing in this picture.
Off Road SHO
Moderator
Is it a U-bolt type or a ****** type? Call me and I'll walk out to the shop and see what I have. I'll be coming into town today and could drop it off.
Tom
SHOVNST
Blood type: SHO+
Niwot, CO
I didn't want to put this off any longer and went to the hardware store today for nuts. I installed this all original factory exhaust system Monday and have been driving around with NO nuts on this clamp since then. Thankfully this junction is VERY tight from the factory and nothing moved.
I got two M10 x 1.25 nuts on the U-clamp but they had more resistance than I would have liked. I still don't know for sure what the actual size is supposed to be. This exhaust system has always been in AZ and is in amazing condition for its age but there is still very minor rust on the threads. With that said the size might actually be M10 x 1.50 and the corrosion allowed me to get the M10 x 1.25 on with a little muscle.
Either way the nuts are tight and NOT coming off which is what I ultimately wanted. However, I'd still like to know the actual size because I'm OCD like that. :nut:
SHOVNST
Blood type: SHO+
Niwot, CO
The reason why I went with the M10 x 1.25 size is (I thought) I tried a M10 x 1.50 and that did not fit. I'm now thinking that nut was not the size I thought. Oh well, the clamp is tight and those nuts never need to come off!
