revhardSHO
I have my 3.2L down to the block, everthing is out but the crank (oil pump is off also). I was turning the crank and just checking for any free play when i noticed a small, puzzling noise. The "tick" noise I get only occurs when im rotating the crank one way and then immediatly start turning it the other way. Exacly when it starts turning the opposite way it makes a destinct "tick" noise from the Number 3 main bearing assembly. Anyone know if this could be a main bearing? Weird b/c it only comes from the #3 main bearing assembly, thats the only reason it got me thinking. THe crank is fully lubed and all the bearings have oil.
what could it be?
thanks in advance
what could it be?
thanks in advance
