Lincster
Hey there..... was wonderdering if any of you have a similar problem with your trans? 92 MTX 5 sp. rod shift. 1st it's notchy....the warmer it get the better it shifts, but at times it is still very notchy. I usally just double clutch it all the time, it shifts o.k. then. 2nd when I redline the machine then stepping all the way on the clutch, the shifter feels like it wants to be wielded to 1st gear.....all other gear shift out of gear smoothly. 3rd it's very noisey...when I step on the clutch the noise stops.....also at that same instance it makes a funny "whhheeeeeee" sound. It only lasts for a few seconds. So campers what do you think? Thanks.
