93SHO_2
I have a hollow knocking noise in my 93 AT SHO that is loudest at about 1,500 RPM and stops at about 2,000 RPM. The noise is worst at 1,500 RPM at decleeration. The car runs great with no overheating. No codes. The noise sounds to be in the upper part of the engine passenger side.
Phase I - replaced the water punp (did not solve the noise probleme but cooling id working well)
Phase II - lovely Memorial Day weekend replacing the left (radiator) cam tensioner, popping the exhaust cam out and eyeballing the cam-gear-chain installation without an allignment tool[the 93 tensioner pad is orange while the 89 cam tensioner pad is black, the 93 orange tensioner pad seems to be held on by 2 screws and appears to be replacable, is this pad still available from Ford?
Noise still persists but I no longer have oil in my plug wells after the cover gasket kit (Felpro VS50378R $88.99 at O'Reilly) isntallation. [Ford wanted $379 for the same kit with plug well seals]
I also cleaned the EGR passagways and for the first time code 332 is gone!!! The car runs even better, I'm about to live with the noise and tell all the Honda drivers I have a "solid: cam.
I disassembled, cleaned and painted the intake manifold, about 8 hours, (there are a lot of parts in that manifold. I miss the Edlebrock 2120) maybe now those 19 year old girls with the belly button rings hanging arround the Hondas will flirt with me.
I checked all the valve clearances, theye were 33 and 20, someone must have done the 120 (I bought this one with 140K after the previous owner paid $500 for an alternator and $2,500 for a tran rebuild and lost patience with SHO's.)
Cruel design joke = the tiny screws on the EGR solenoid (and the Cam Position Sensor, and maybe the TPS) are 7/32 , not metric.
Phase III - replace the Cam Position Sensor next weekend unless alternate sage advice directs me elsewhere.
