Ok for quite awhiel I had been getting a "pop" noise when going down and incline or turning the wheel form the fromt of the car... Now that seems to have gone away for the time being but there is a almost constant "loose rattle" that seems to come from the front end when going down gravel roads or unsmooth surfaces... it almost sounds like a loose brake caliper would(not that though) ... not really a metallic sound..... but a dull constant loose rattle.. I've had two seperate places look at it and they tell me the sway bars and ball joints are fine and nothing appears to be loose at all... with the exception of.... it looks like ride height sensors(thats a guess) these are both very loose and pivot freely. This noise seems to have gotten worse as of late and it can also be heard when the brakes are applied (it needs the rotors turned at the moment so that creates the vibration) Heres the list that I've looked at thus far:
Sway bars Tight
Ball joints ok
Cat converter all not broken
Sway bars Tight
Ball joints ok
