No turn directionals
spazmoid
RI
So within 2 hours of using the auto headlights for the first time in years really, my turn directionals stop working. I had recently taken my aftermarket fogs off because one bulb burnt out and its impossible to change the bulb with them on the car. I just taped up the wires and left the switch off. My friend told me my outer brake light was burnt so i switched the bulb with the one right next to it, not having a replacement, and hoping the directionals didn't work because that bulb was burnt. It doesn't seem like the bulb is burnt though because the same light didn't work again and the "bad" bulb works fine in the other socket. I ordered a new multifunction switch hoping it's that, does that make sense to anyone, the 4-ways still work fine too. Does anyone think that using the autolights or taking the fogs off could've caused the problem and does anyone else have a fix other than changing the multi-switch? Thanks
__________________
spazmoid
RI
ya, they did, everything is fixed now though. It was the multifunction switch. Thanks for the response though
Pro*banshee
PA, 16066
Do the side indicator lights turn on when you try to signal. (They don't flash)
Johnmon, the cornering lamps aren't wired to the same circuit as the turn signal. They are wired in with the headlight circuit and will work despite the turn signals not working. You can try it yourself by not putting your key in the car, turning on the headlights and hitting the signal stock
spazmoid
RI
its the turn directional/wiper/high beam/washer switch on the column
thatSHOguy101
