No Start
3Xtream
NH
Heres the scoop. Drove to store car ran fine. Got out did some shopping come back and all I get is one click from the selinoid. Tap on the starter nothing try jumping the starter and every once in awhile it woud spin but not engage. Anyway get it towed home change the Starter with a rebuit from advanced auto. After install get in car it starts right up the first time then try again and one click is all I get Battery is good connections are good I dont know why she would start once and then just click again. Any suggetions would be greatly appreciated. Oh Its a 93 ATX 3.2L
RStalveyARFF
too many shos
Georgetown, MA
there are some connections near the starter that can work their way loose over time, you may want to check those for corrosion. I couldn't understand if you checked the battery, but it may be worth just running cables to another car and trying it again. Finally, there is a small black wire that runs from the negative battery cable. Follow that to where it is grounded and make sure that is good. I wish you luck discovering the cause of your problem!
