marvsho17
Joshua S.
NO START, code 95, icrm or fuel pump?
My 91 has been running fine up to yesterday. As I go to start the car in the morning, it just cranked. Trying to start it today it would to the same--crank and crank. When I would run the codes I would hear clicking from the engine bay but no priming of the fuel pump.
Today I ran the codes, got 95 and 67.
95 (O) Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
(R) AIR not Diverting (AIRD) - Air Injection
(M) Possible bad fuel pump ground or open between fuel pump and pin 8 at PCM (Fuel Pump Monitor signal) - Power / Fuel Pump Circuits
After reading that the description of code 95; I tapped on the icrm box above the radiator. I then tried to start the car, it would almost turn over and start this time. After riding my motorcyle to school the past few 50-60 degree days I'm ready to cut a hole in the rear deck. Are there some grounds to check besides the one on the intake? Or should I just pony up the dough for a new pump?
Thanks in advance.
Thanks in advance.
