no start after putting on intake mani
ryein7
KS
hello everyone i am having a little bit of a problem. I replaced the couplers on my intake manifold today. i got it all put back together and now the car turns over but no start... i am quite confused. i am not sure really where to go from here seeing as how i have checked over everything i unplugged and it is all plugged back in :oogle: the battery was unhooked while i was working. is there is a change a fuse popped or something when i put the negative back on the battery? i dunno what to do :( i would really appreciate everyones help
Ishodu
Most of the time when people when people remove the intake they forget to reattach the ground strap on the rear of the intake, its stock location is on the top of the rear passenger side intake support. It's either that or the intake cross over tube bolts are not in or tight.
frosho
WOLFMAN
Tyngsboro, MA
Double and triple check everything that was taken apart or disconnected. I had the same problem after putting my freshly painted intake on a while ago, turned out the DIS was unplugged on one side. :brainfart:
ryein7
KS
how would the intake cross over tube bolts not being in effect starting? both dis plugs are in. ill check that strap and let eveyone know
shovermont
unleasing my 91
Vermont
injector pattern, if you pulled those and hooked them up with out remembering where they go then it wouldnt start. getting gas pressure on the rail?
dan.delargy
