No Speedometer
mosho93
Well-Known Member
Wausau, WI
I currently have had problems with my heater core, so i did the heater core bypass yesterday till i can come up with the cash to fix it permantly. and i got back in my car after i had it all done and now the speedo doesnt work. what might of caused this? I was working back by the firewall where the heater lines go in and out and thats the only place i was was working in. Any ideas??
Frankiek3
you might have made your speedo cable mad.
it comes out on the drivers side into the engine bay, it has one or two places where it might have disconnected
until u fix it, use the RPM and gear to measure aprox. speed
Ishodu
Check the connection between the lower and upper cable. Its not hard to see, you will notice the cable coming out of the firewall. Make sure its connected together. And if it is you can remove the clip and try turning it while a partner watches the speedo to see if it moves. If not you have another connection behind the cluster or the unit itself issue. If it still does you may need to go lower to the lower speedo connection and check out whats going on there.
mosho93
Well-Known Member
Wausau, WI
I messed around with some cable and such but nothing seems to be fixing it. Can soembody post a picture of what i might need to check out? Any help is greatly appreciated. im starting to get the tach speeds down but i do miss my speedometer! thanks
