No Spark???
Andrew Tilson
Chubbuck ID
I fixed my compression problem and now I have no spark, cps seems to be working I have a tach reading. and it had spark before I tore the thing apart. ideas on where to go from here???
fredhurderjr
www.neshospecialists.com
Did you plug the DIS module back in? Did you disconnect the computer's ground? Just a thought.
<small>[ June 29, 2002, 12:07 AM: Message edited by: fredhurderjr ]</small>
Andrew Tilson
Chubbuck ID
My DIS is grounded at least according to my ohm meter. if the computer's ground was bad then wouldn't it not be able to go into diagnostic mode?
jcostantino
Coral Springs, FL
Computer ground is a single connector from the negative battery terminal to a barrel connector that snaps apart and should be clipped to the right-side strut tower.
Jeff
Andrew Tilson
Chubbuck ID
I fixed it!!!
I replaced the crank sensor even thought the tach was moving I desided to have autozone test it while I could still get to it, it came out bad and upon closer inspection I can see that the wires going into it were quite frayed, replaced it and now it runs like a scalded cat! I had forgotten just how freaking quick this car is, now all I have to fix is that damn oil pan leak... but that can wait for another day
