NO SPARK
johnny boy
Bridgeport,Connecticut,U.S.A.
Hi i need help,
well i just bought an 89 ford sho nice car it ran fine i drove it home about 50 miles but when i got up in the morn it would not start its got plenty of cranking power fueses are all good its getting feul but no spark,
I changed the coil pack and still nothing i put a new egnition control mod checked the crank mod its fine it moves when i crank it over, still nothing im tryng to narow it down so can do it my self before i take it to my local ford and drop some crazy money. please help i need my car. thanks
Rob94
Northbridge MA
I assume this is the John that emailed me a few days ago with this problem?? I am thinking CPS here, but as I said in my reply, you will get a much better idea of what is going on by posting here, and letting the collective knowledge of the forum give their opinions.
Rob
White 94MTX
K&N Filter otherwise stock
noSHO
ohio is for hustlers
Some easy checks to do before you get into more serious solutions:
Check your battery cables, make sure they are tight. My car wouldn't start after the 60k-cause? Battery wasn't tightened down.
Check the ground on your DIS. I installed a new intake and the DIS didn't ground right, and I literally WATCHED my car stop running in the midst of a KOER test. It was really odd.
Pull codes. You might be storing something that doesn't show on a CEL.
-Dave
green/black 92
8359139 68b0 00C8006C
djsSHO
Ford Nut
Buffalo, NY, USA
Did you check your fuel pressure? If it wants to turn over and you have spark, you might not be getting enough pressure on the rail. 39lbs. is the ideal pressure. Something to look into. I know mine started falling off due to a fuel filter that had been on the car for 80k miles
. New filter and all was well in SHO land for a week...yes week...the following week a CV joint seized and it was in at the dealer for a week waiting for parts...
Derek S.
94' MTX SHO
Taylor 8mm Spiro Pro's
K&N Panel
Couple o' gauges
MOMO 12" Sub
"Gretchen"
