no power, IE no dash lights at all
kevingotashotoo
200 or so ponies
peterborough,ON canada
in the middle of swapping starter solenoids, forgot to disconnect ground to battery got some sparks at the solenoid posts...now no power to the whole car...battery has a load of 12 volts still...what should i check?
naval-avi8or
Chesapeake, VA
Check the master fuse block in the ENGINE COMPARTMENT. If all is good then you melted a fuse link in the main wire to the engine compartment fuse block.
Redskull
Badass Mo'fo
New Haven, CT
i thought only the GEN I's had fusible links, and the only GEN II's had the high amp engine compartment fuse block....?
naval-avi8or
Chesapeake, VA
The Gen II has three fusible links.
dstig1
Hudson, WI
In the wires leading to the high current fusebox in the engine compartment. Right between the driver's side strut tower and the firewall, up by the windshield cowl. Wiring diagrams are a sticky on one of the threads on this site...
kevingotashotoo
200 or so ponies
okay power is back on....starter is okay same with solenoid...still no start
not even a crank its like im trying to start it without pressing in the clutch
bypassed the clutch interlock...still nothing
i forgot to mention when i first went out to start it when i realized it wouldnt start the tach jumped
Redskull
Badass Mo'fo
New Haven, CT
It should be 12v with the switch to 'start' with the clutch in...so test it before the ignition switch, after the ignition switch, before the clutch interlock, and after the clutch interlock. That will narrow it down. The EVTM is a friend.
if you're feeling froggy, you can always try the 'screwdriver start' method (short out the two terminals of the solenoid with a screwdriver, it ought to crank). That'll rule out starter issues.
ohfosho
ontario SHOwner
ontario, canada
does the starter make a click when you put the key forward? if it does, the starter is most likely hooked up properly, but you got a bad one. the click is the solenoid trying to engage.
if there is no click check your wiring again and all connections. last resort grab another starter.
