kevingotashotoo
200 or so ponies
in the middle of swapping starter solenoids, forgot to disconnect ground to battery got some sparks at the solenoid posts...now no power to the whole car...battery has a load of 12 volts still...what should i check?
kevingotashotoo said:in the middle of swapping starter solenoids, forgot to disconnect ground to battery got some sparks at the solenoid posts...now no power to the whole car...battery has a load of 12 volts still...what should i check?
Redskull said:i thought only the GEN I's had fusible links, and the only GEN II's had the high amp engine compartment fuse block....?
