olympic
It was posted a long time ago that the proper compound to use on the back of the DIS module was heat sink grease, not dielectric grease. Well, none of the Radio Shacks around me carry the stuff anymore. So I skipped down to my local computer retail/repair store to see what they had. The salesman was helpful and showed me "silver-based heat sink grease". It comes in a 1.5g syringe and cost about $5. He said this is what they use on all the more powerful CPU's so it should be good stuff.
One tip for using it, don't concern yourself with getting even coverage on the back of the DIS. Just clean both surfaces well, apply a large glob of the HS compound on the back of the DIS near the center and screw it on. The grease will spread itself out. You don't need heat transfer all the way out to the corners anyways. Hope this helps someone out.
:corn: :burn_out:
that is the best I can do...haha
