Marccus
I had to replace bulbs on my instrument panel and after bolting connecting the panel back up and bolting it in, I have problem with the lights. eek!
When the light switch is moved to the first position the parking lights work fine; when I move it to the 2nd position (headlamps), the low beams don't come on and I get a clicking sound from the switch and several at other areas behind the dash - near the radio, etc. madflame
No smoke or any blown fuses. It just keeps doing this when I shut the switch off and try it again.
It seems unlikely that the instrument cluster repair - changing bulbs - or reconnecting the panel could have anything to do with the lights.
Could it be that the headlamp switch just went bad at the same time? shrug
Also, if use the auto lamp feature to turn the lights on (when the ambient light is dark enough), I get the same clicking noises. madflame
Then this makes me believe it is not the main light switch unless the auto lamp feature is somehow tied in with the headlamp switch.
Most surprisingly, the high beams work when I pull in on the directional signal lever to activate the high beams.
I can drive at night like this, but it would be annoying as I would have to hold the directional signal lever all the time; if my hand slipped or tired, I would have no lights. rofl
Any ideas on where to troubleshoot? headbang
