NO HEATER !!!
jonysho
owasso Ok. U.S.
It starting to get cold and I just discovered my heater is not working. THe air that comes out get semi warm but near enough to warm up the car. THe heater core seams to be fine so I am at a loss. Is it possible my EACT is messed up.
ANy help here would be appreciated. THanks.
projectSHO89
SHOless In St L
Run the EATC self test. You may find that you get a "02" error code.
Other thing to check is to see if both heater core hoses are hot when the engine is at operating temp. If one gets hot while the other doesn't, the core is clogged and will require backflushing or replacement.
Also, a defective thermostat can cause this.
Steve
<small>[ September 22, 2003, 10:18 PM: Message edited by: projectSHO89 ]</small>
