FRDSHOGRL93X3
THE LINES GOING THROUGH THE FIRE WALL ARE WARM. AIR IS BLOWING OUT THE VENTS, DEFOGGER, AND FLOOR ONLY PROBLEM IS ITS COLD AIR. I CAN'T GET HOT OR EVEN WARM AIR TO COME OUT. WHAT THE HECK IS GOING ON?
Slo-Sho said:Car should be warmed up before running the test. Press both FLOOR and OFF simultaneously, let go, then press AUTOMATIC. Wait for the diagnostic, hopefully you will get a "888" then press the COOL button.
Just ran out to the 95 and tried it. It works!! Got 888 and all the lights lit up. You know what I was doing wrong? I was holding down the floor and off button and then pressing the automatic. On shotimes instructions it does not say to let go of the floor and off buttons after pressing them. I guess I was thinking it was supposed to be a three finger salute, ala windows style.FRDSHOGRL93X3 said:Ok Heres The Deal, The Eatc Coded Out 02. Blend Door Problems. Looked In The Taurus Bible And Discovered This May Be Quite A Job To Change The Blender Door Actuator. Does Anyone Know Of An Easy Way To Do This Without Tearing The Dash Apart Or Even Just A Way To Jerry Rig It????
That's interesting. The replacement unit that I purchased from Ford did not have a motor that was interchangeable with the existing bracket. I had to replace the bracket, as well:Electricat said:Also, the blend door motor comes with a new mounting plate. The plate screws on, while the motor unit itself snaps onto the plate. It is nearly impossible to get at one of the plate screws, so instead I just left the old plate and snapped the new motor unit into it.
Rockledge said:That's interesting. The replacement unit that I purchased from Ford did not have a motor that was interchangeable with the existing bracket. I had to replace the bracket, as well:
http://www.shoforum.com/showthread.php?t=31156
My new motor snapped right into the old bracket. The possible incompatability is a good thing for other people to know about.
