As some of you know, my attempts to take the new and improved turbo SHO to the Indy convention were foiled. The day I was supposed to leave, I got it all back together but could not start it. I racked my brains for a few hours, tried all sorts of remedies, but none worked. Here are the symptoms. Here are the symptoms:
When I turn the ignition on, I hear no whine from the fuel pump. It simply is not running (or at very low speed, because it did start and run for about 10 seconds one time, the other time it started but I shut it off).
Also, my starter would only engage if I shorted across the solenoid.
I ran codes, and this is all I recieved - 95 (when I had the GEN I computer in it), and 542 (when I had the GEN II computer in it). They are the same code though, fuel pump circuit always open, or bad ground, something of that nature.
I checked the inertia switch, even made a jumper for it, no go. Swapped ICRM's, swapped computers, swapped solenoids (but will try again with a known working one in a bit), cleaned battery terminals, connections, etc etc, no go.
I see no reason why fuel pump would be bad. It started fine prior to it sitting for so long. But, once after the winter I tried to start it and it would only crank for a long time. So there is a chance I need to swap in a new pump, but I want to check all other alternatives first. Plus, the starter is not engaging without shorting across the solenoid, so my problem is not isolated to the pump.
Any other ideas gentelman? I have not touched the thing since I got back, but before I start breaking into it again I thought I would see if you all had some recommendations. I know it is something simple, probably staring me right in the face, but I just can not put a finger on it.
TIA.
TIA.
