Ian
1993 ATX, blowing brake light fuse even with plug disconnected from brake switch. Cut green with red trace wire, and supplied power to switch from other fuse, brake lights work. Before where wire cut 2 green with red trace wires, cut end went to brake switch other end to fuse, wire teed off (other green with red) where does teed wire go?? Help would be great. or diagram if possible, I'm electrian with diagram can trace.
