nitrous
red89sho15
harrisburg,pa
just out of curiousity (or owever you spell it) i was lookin into nitrous but i dont want one of those fancy direct port isnt there any simple cheaper like 50-75 shot kits that will work on the shos
SASHO91
Zoom Zoom
San Antonio,TX
ZEX 82011....
a search will yeild an A$$ load of info on the subject. :thumb:
its been the top nitrous product for the SHO's.
BTW, its a Dry kit as that is THE only type to run with the SHO. (other than a direct port into the secondaries)
EDIT: within the same minute..... WOW....
CosmoSHO
Fort Worth, TX
LOUDSHO92 said:
We do offer the kit here at a cheaper price: SHOBros
Your SHOBros add is misleading. :nut: The Zex kit does NOT monitor the AFR at all, and certainly has NO capability to shut down the N2O if the AFR gets lean. The NMU only monitors N2O pressure, and adjusts the signal to the FPR to manage the fuel pressure at the rails.
It's up to the operator to insure the fuel delivery capacity (i.e. pump, injectors, and FPR) as well as the plugs and tune are compatible with the nitrous shot (jet size) configured. A wideband O2 is highly recommended.
For what it's worth, I'm safely running a nitrous shot significantly north of 100hp with a Zex kit on the FreakSHO.:biggrin:
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
CosmoSHO said:
Your SHOBros add is misleading. The Zex kit does NOT monitor the AFR at all, and certainly has NO capability to shut down the N2O if the AFR gets lean. The NMU only monitors N2O pressure, and adjusts the signal to the FPR to manage the fuel pressure at the rails.
The ZEX system doesn't even do that. The rate of FP rise is propertional to the N2O pressure. It's a function, not a monitor.
That's why I like the NOS system. It's got 2 solenoids for safety (ZEX only has 1) and an N2O pressure regulator for fuel pressure adjustability and consistancy.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
NOS 5115, I think. It's a Mustang kit pilled for 75hp.
kzoosho
Holset HX52
grand rapids/kalamazoo
Geek SHO said:
Or you could just buy the tried-and-true Zex kit and let the NMU do the work.
The only thing is some people dont like dry kits seeing that you can run lean and im sure that texantony will agree . if you just want a little more grunt yes the zex is the only known kit to run. but then there are people like me that want alot of grunt and the zex just wont do it
Cocoa,Florida
the zex kit can be upgraded to run a higher shot than 75.
kzoosho
Holset HX52
Safely? no. i would never run more than a 75 shot. Dry kits are just to iffy. All i have and will keep running is wet kits. There are less variables. Also with a wet kit u can run bone stock everything up to a 125 shot. But everyone has there own opinions. I cant make anyone run a wet kit i just know i am.
Geek SHO
SHO Addict
Rohnert Park, CA
He said he didn't want a fancy direct port injection nitrous system, which is pretty much what you have to do with a wet kit on a SHO, right?
Eventually, I might put a standard wet kit that injects after the throttle body, but my intake probably won't have any fuel-pooling issues. ;)
kzoosho
Holset HX52
O yea forgot he he. well for a dry kit yes the zex kit is the best 80211 i believe.
