nitrous question
JMoff92
Rochester, NH
I am considering putting a zex system 75 shot in my sho, maintenance is up to date, only question I have is do you think it would be necessary to get a quaife before I put it in?
SHO--ripper
928 Euro
winsted,CT
I second what kenny said about the stock disc. Mine started slipping after 10lbs of N20.
Bare minimum put colder plugs in and a reinforced motor mount if you are using N20. If you like the dragstrip, buy sticky tires and a non-stock clutch.
whfla
use the 55hp jet , that way you don't need to mess with the timing , i have the zex too and it is fine with the 55 jet !..........and if you got a chip u got to take it out unless it is tedb chip then he can reprogram it for you , ...good luck either way !
