Newbie Question
93shonuff
Houston
i having a hard time locating where the t-stat goes. would someone show me with a little ms paint illistration. ty
btw all u need is a gasket and t-stat right.
AREA 91
PA SHO SHOP
Area 91
Follow your upper radiator hose to the engine. The T stat and seal are behind the aluminum housing. There are 2 studs with nuts that get removed.:thumb:
290
Loser of Keys
Sterling Heights, MI
Also the T-Stat uses a rubber o-ring instead of a regular paper gasket like most cars. make sure you have one before trying to change it. And make sure you dont overtighten the bolts because the studs break easy
