New X-Calibrator Group Buy
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
Mr Anonymous said:
Same here Doug, especially since mine will be different from everyone elses and I don't know how long you hold on to them. [email protected]
Actually, I keep all of them on my server. I've got several hundred tunes saved and saved again and then backed up. I even back them up to a keychain drive along with my entire company file. These 1G thumb drives are pretty cool.
You guys lemme know when you start getting the tuners. They went out USPS Priority mail on Wed. They should start hitting your door today, Sat or Mon.
__________________
3.2L headgaskets in stock!
Doug Lewis
[email protected]
Ford Performance Specialists Inc.
Atlanta Georgia
770-949-7191
http://www.fordspecialists.com
2001 F-250 Powerstroke-
Garrett turbo - 700ft-lbs
1996 TR SHO-
Long tubes - bottle fed - low and fast
1989 CR SHO-
Shaftdrive supercharger - 400hp
DavidT
TN
I can't brag enough that that is the BEST $400 spent in performance modification to the gen.3 sho!!!!!!!!! :salute:
Bob Knudsen
Claremont, CA
Received my tuner today and will install it tonight. Doug, I note on the invoice that the programs are for 87. 89. and 93. Here in California we cannot get 93, my choices are 87. 89, 91, and 101 octane race gas. Do you have a separate program for 91 that I can use? I expect I would be giving up some performance if I used the 89 program. In the interim, I expect I will run the 89 program or run the 93 program and add some octane boost.
California not only gets the most expensive gas (except for maybe Hawaii) we also get the worst when it comes to octane.
Bob Knudsen
jrcrum
to the limit.
3,967 ft above sea level
got mine today installed LOVE IT! thanks and also as to the gas deal in Nebraska I've only seen one pump with 93 :p so not just california but we don't pay as much as you :p
avocadoman1
Channel Islands, CA
just picked up the mail and there it was!
I immediately installed it.
used the 87 program...hey, why not save $.20/gallon?
it is unbelieveable!!! no noticeable loss of power using the lower octane.
the shift's are great, and it knows when to downshift so as not to "lugg" the engine when I get to a slight hill at 35mph.
I "gotsta" believe that it will extend the life of my new torque converter.
all I can say is WOW.
the best $370 I've spent in a long time.
DavidT
TN
87 octane with the 87 program is all you need. There will be NO noticeable gains in any way with the higher octane gas/ and/or program. This was proven true at the 1/8 mile track.
avocadoman1
Channel Islands, CA
Interesting finding because the XCal website says:
Question: Does your product require a higher grade fuel than 87 octane?
Answer: While some of our products give you the choice of running 87 or 91-93 octane fuel, only the use of 91- 93 octane fuel in gas powered vehicles will increase the Horsepower and Torque output.
I naturally (and probably ignorantly) assumed that since 91-93 octane would increase Horsepower, that 87 octane might decrease it.
Good info to note. Thanks.
Bonestock
It's paid for!
Albuquerque, NM USA
The tuners will come with the three tunes of your choice, data connector for programming the car, instructions on how to use the tuner and an SCT badge. I'm also including a Data Cable for programming the tuner.
I just got my tuner, Invoice, Instructions, and badge -but I didn't get the data cable. Are they available?
3.8Lwagon
Shaggen Wagon
doug,
I got everything (including cables) but i received an x-cal 1 not a 2.
James A.
2000 Taurus 3.0 durtec
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
X-Cal 2's use a simple USB cable to connect to the computer. This is for the datalogger and reflashing the X-Calibrator. There is no special datacable for the X-Cal 2's.
The X-Cal 1's DO require a data cable for reprogramming.
James,
Obviously the mixup is on my end. I shipped the tuners out based on the last list dated 08/08/05. You should have gotten an X-Cal 2. PM me or give us a call at your earliest convienence and we'll figure out a solution.
masho95
got Zex?
Chicopee, MA
Well actually both that answer and your assumption are wrong. Higher octane gas does NOT increase HP or TQ. The octane rating of gasoline is only a measurement of it's ability to resist precombustion detonation. But using higher octance gas is necessary where engine combustion temperatures will be higher such as nitrous. So basically if your engine isn't knocking on lower octane gas, you won't see any improvement in mileage, HP, or TQ with a higher octane gas.
SableOHC
Xcal arrived
My Xcal2 arrived on Friday. I have some questions before I install:
1) The invoice and the SCT booklet both list the programs available, but they don't match. Can you let me know the correct list? I'm at work and don't have it with me, but I can send you both lists I have when I get home, if you need them.
2) The booklet shows the base program as GHJ7. My car is currently GHJ6, at least that's what the sticker on the PCM claims :D I checked back and noticed I hadn't sent that info with my order? Is the GHJ7 just an updated version of the GHJ6?
Thanks
SableOHC
Octane
Higher octane fuel won't give you more power, but it may allow you to run with more spark advance w/o detonating. The extra spark advance (applied correctly) is what gives you the power. The SCT FAQ wording is a bit misleading.
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
That's correct. It should work just fine.
Let us know.
__________________
Doug Lewis
[email protected]
Atlanta Georgia
770-949-7191
1996 TR SHO-
1989 CR SHO-
3.8Lwagon
Shaggen Wagon
i flashed my ecu today. wow the car actualy shifts. i couldn't feel one shift before. but now it shifts realy firm and pulls harder after 4.5k
Wess
Jarhead
MD
Not for the faint hearted
Common side effects are:
firm shifts
torque steer
permanant smiles
My car scares me now! :biggrin:
Thanks Doug! :hail:
r0nd3L
Lombard, IL
Hey Doug, how much would X-Cal cost me now? Sadly, I didn't have enough money during the group buy, but managed to gather some now. Please let me know.
Thanks,
Matas
SHO Dude
Sponsoring Vendor
Sponsoring Vendor
Southeast
X-Cal 1's sell for $470 and X-Cal 2's sell for $499.
Give us a call, gottem' in stock.
__________________
Doug Lewis
[email protected]
Atlanta Georgia
770-949-7191
1996 TR SHO-
1989 CR SHO-
