New (to me) SHO Clutch,ECC Questions
tbalderm
Morrice, MI
I just bought a 95 MTX on Saturday. The car has 94k miles on it. My questions: 1) my clutch sees to engage very low in the pedal travel (about 2 inches from the floor), is that an indicator of a worn clutch? Any adjustments that can be done? 2) the ECC blows warm air when set on anything other than 60. How do I get codes from the system? And has anyone had this problem before?
noSHO
ohio is for hustlers
I don't know about your climate control problems, but in regards to the clutch, high engagement is bad. If your clutch is engaging low to the floor you are in good shape.
-Dave
Green 92 77k coneless, fishtanks, K&N panel filter, SHOnut reinforced motor mounts, SFCs, Perf. Plus Y-pipe, Summitracing Turbo Mufflers
T
ThatSHOkid
Guest
there is a test u can do on it. the directions are on www.shotimes.com and it willg ive u some codes that the deifne for you
i am going to run that test tomorrow on mine also
1993 White/Tan SHO MTX 96k Miles
[*] Eagle Super White Headlights ** American Products Company Super White Reverse Lights ** Hibrid Double Watt Super White License Plate Lights ** Colgan Custom Bra From Cincy SHO ** Gen. 2 Font "SHO" Windshield Banner ** Superchip Performance Chip ** Blacked Out "SHO" Lettering ** Sho Shop Y Pipe ** Coneless & Boxless ** K&N Filtercharger ** Blazertech Super Clear 55w Foglights ** Ventshade Sunroof Wind Deflector & Vent Guards ** GTS Headlight Blackouts (on order) ** Sony 10 Disc Changer ** All Possible Options
[*] Coming Soon: Tinted Windows, Sub Frame Connectors, Strut Tower Braces, & A Sig Pic!
[*] My Name: Jay/Jason/Hubes
[*] The Car: Zsa Zsa
[*] AIM: KingPin641 (I am a NESHOC member)
***"Drive it like you stole it!"***
nothingtoseehere
the SHO has a self adjusting clutch. Simply turn off the car and lift the clutch pedal up with your foot, if you here a click it needed adjusting, then slowly push it down all the way. Should be checked every 5,000 miles
-RANDY-
