New sound with sound clip
trainguy1989
SHOtarted
Wichita, Ks
My car developed a weird fast paced chirping sound on my 1994 SHO ATX. It just started this afternoon. I have had my car on jacks for about a week and a half do to the fact I did not have the parts to finish the car with. I replace a cv half-shaft and lower control arm on the drivers side. I also did a brake job on both sides. But from what I can tell the noise is coming from the passenger side. Does not seem to have anything do with the parts I replaced. Noise is loud during idle near the belt system.
Here is the sound....
http://www.youtube.com/watch?v=EGTLaUDkyuk
Thanks
David
89SHO X2
Wa
could be a pulley. maybe pull the tire off and listen around. maybe have someone on the gas pedal
89SHO X2
Wa
pulley bearing most likely. hard to tell what because the timing set has a tensioner pulley. and you have the water pump, and assessory bearings. my idler pulley on the timing belt was shot. i would seriously do a front end service checking every bearing for damage. the timing pulley could be a big issue. it gets a lot of abuse. it would be a muffled chirp compaired to the belt system outside would be noticabley loud. let me know what you find for the cause.
