New SHO and a few problems
fast4door
wichita
Ok picked up a 92 5spd car over the weekend and I have a few issues with it. Forst off the Cruise doesnt work. Checked the fuse and no the problem so what else could it be? The module itsself? Also the fogs dont work same thing checked fuse and not the problem. The swithc will light up and they are connected at the harness.
Joe
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
Joe
hello man,
for the cruise control check the cable at the throtle body if its disconected or broken, also for the fog lights replace the bulbs and you should be allset..
good luck
endri:thumb:
93rev2sev
Hockeytown
And the cruise in 92's had a vacuum canister inside the drivers fender behind the corner light. If it's not getting vacuum, the cruise wont work....and you will lose a little performace if it's leaking.
