Just to clarify, you had an under hood fire, you changed the burnt wiring, and at the same time, replaced the EEC, also know as the PCM and ECU. When the repair was done, the bad mileage symptom appeared.
If you put the slightly burned EEC back in the car, would it run?
The EEC runs everything, but it needs wires to get the message out, you may need to look into a new engine wiring harness, but it would be helpful to get the answer to the first sentence.
There are 60 pin positions on the EEC and only 7 are unused. You may be in the right area, but maybe the wiring is the issue
No, there wasn't actual fire under the hood. Technically, the wires just burned up from arching, I'm guessing. I think whoever did the wiring job originally must have not covered all the wires properly, and two of them crossed or arched. The wire only burned when the car was running, not when it was turned off.
I didn't replace the PCM/EEC for a while after this happened. I replaced the burned area of wires, the starter, and that's it. That worked for a while, then I started having a problem. The car would just die randomly, or it would drop RPMs for a split second and pick back up again, the same symptoms as a bad crank sensor (a problem I'd had with one of my other SHOs not long before that. I replaced the crank sensor and found that it didn't fix anything. The problem persisted. So I eventually replaced the PCM (which smelled burned) and it fixed the stumbling problem, but the gas mileage problem started occurring at that time. Around the same time, I had to tighten a hose at the fuel pressure regulator, because it was leaking. It's no longer leaking, and the pressure regulator works fine when I test it, so I don't suspect that's it.
If I put the slightly burned PCM/EEC back in the car, yes, it would run, but it would stumble again, just like before.
I don't think the wiring is the problem, only because this problem didn't happen until I replaced the EEC/PCM. Unfortunately, the part of the wiring harness that burned isn't the part that can be easily replaced--it's part of the car's big harness, not the detachable replaceable part of the harness. I had the same thought a while back just to replace the harness, but it wasn't the replaceable part. No way am I replacing the main harness.
Confused as much as I am yet? lol
