Marccus
I just installed new injectors and tested the fuel pressure before installing the intake manifold. Here's what I got:
Fuel pressure fell from:
max of 34 psi to 30 psi over 70 sec (3.4 psi/min)
30 psi to 28 psi in 1 minute (2 psi/min)
28 psi to 26 psi in 1.5 minutes (1.3 psi/min)
I'm using an "Actron CP7838 Professional Fuel Pressure Tester" with the Ford Adapter that is screwed onto the on Schrader valve finger tight. The hose on the gauge screws onto this adapter finger tight. Both have o-ring seals.
The rubber hose length on the tester is about 3 feet and there is a pressure release button the gauge which flushes fuel to a small clear plastic hose which can be directed to a towel or bottle.
I pressured the tester cycling the fuel pump eight to ten times and then flushed the fuel out. I did this about ten times to make sure all the air was out of the system and the max pressure was repeatable. When I press the pressure release button on the gauge, I can still see very small (pin head size) bubbles in the fuel.
I stated what the set-up was like because I am thinking that this rate of pressure loss may be acceptable with all the hose and finger tight o-ring connections versus a direct gauge connection with NPT fittings.
It's getting dark soon and I have to get the intake manifold on! Any comments?
