I'm going to start off this thread by saying that this Blue 95 has been an electrical nightmare since the day I bought it. I thought that I had everything corrected and now this...
I have a thought about what the problem might be but want to see what others have to say. The car starts and drives. It drives great. Just put 1100 miles on it going to the convention and back. Now I have some sort of short in the dash it seems. As the car warms up, the temp gauge will continually rise until the needle is almost pointing straight up. Well past the Hot mark and into what should be boiling over stage. The car is not running hot. I have aftermarket gauge and it stays right around 190 while idling. While this is happening the fans are running constantly. If i have the headlights on the dash lights will gradually get dimmer until you can barely see they are on. With all this happening, if I turn on the wipers the dash lights get bright again and the temp gauge will move. Turn the wipers off and the dash lights start going dim and the gauge needle stays pegged straight up. Also, when I turn the wipers on the EATC display will flicker if its off and if its on the display will flicker and the EATC will cut out the entire time the wipers are on. Turn the wipers off and the EATC will come back on. All of these things appear to be connected, the temp gauge, dash lights, wipers, and EATC. Everything else seems to be working fine. I can drive the car as long as I dont need AC and wipers at the same time.
Thoughts?
Thoughts?
