glxrustang
SHO Luv
My back brakes have been getting super hot and smell burnt, I changed the rotor, pads, and caliper before, but they are still sticking! I had to put new pads on and when I did, I removed the E-Brake and greased the caliper pins with the brake grease. After I re-installed the caliper, I moved it back and forth and it glides nice and smooth. So why do they smell burnt, AGAIN???
Question, the caliper piston didn't compress easy, its that crappy style that has to twist and compress. Could that be an issue.
Change the rubber lines.
, but replace both rear rubber brake lines. Should only cost you about 30 bucks or so, and I can almost guaranty that is your problem. I've had to replace the rear rubber lines on the 3 sho's I've owned.
