Need some quick help - '90 SHO, Aftermarket Radio & Rear JBL Subs ...
AdamITR
Just installed a new Kenwood Stereo into my 1990 SHO. All speakers work fine, sound just okay. However the previous owner "Cut" the wires that go from the JBL Amp in the trunk to the 2 subs. Can I reattach these wires, or will there be a problem???? Thanks.
tery
Silvia survived the purge- summer car
minnesnowta
Why do you want to re-attach those lines? I put kenwood stereos from Crutchfield in four SHOs and just ignored the previous system, connectors all matched up and speaker connections worked fine. The sub in the rear of the SHO at that age is not gonna sound good, its a paper cone and gotta be dried out, Wait...there's only one sub, its in the middle of the rear, the two on the sides of the rear deck inside the window aren't subs, they're full range speakers...I highly recommend putting in new speakers. You won't regret it.
AdamITR
I was hoping to get better audio quality, but was not sure if I would damage anything if I hooked them back up.
Devin
3.Slow
Pacific Northwest
There is no single sub in the 90 JBL, there are woofers held onto the bottom of the deck, and two-ways installed in the brackets. The woofers are what are being referenced in the OP.
You'll want to buy the bypass cable (if not already installed) and buy your own speakers. A good set of 6x9 three-way speakers will sound way better than the stock gear.
tery
minnesnowta
Thanks, I thought...wrongly..that the sound system in them was the same
Devin
3.Slow
Pacific Northwest
You should have two sets of cables in the console: two right angle plugs belong to one set and a single right angle plug and a square plug belong to the other set. Do you have all those?
Devin
3.Slow
Pacific Northwest
This looks like the right harness. I'd have to look at mine ton confirm though and I'm in the wrong state.
AdamITR
So everything is working now, EXCEPT ... I need a driver side rear sub speaker.
mavericksav
Moscow
Hi. Make me please some pictures of your woofers and Amps in a trunk. I want to restore original sound in my 1991 SHO
vsofouk
Cleveland OH
mavericksav
Moscow
Awesome. May I ask for another favor? now I need photo of amp connection to the speakers. I couldn't imagine that type of fixation of speakers.
