Need pulleys!!
mclarida
Orlando, Fl.
The bearing on my serpentine belt tensioner pully is going out. I need a new one. I would like to replace the other two ideler pulleys as well at the same time. Any suggestions are welcome-93 atx-Emerald-
Mike
AREA 91
PA SHO SHOP
Area 91
Here's your answer.
www.shonutperformance.com
The bearings are listed under the 60K section.
Parts Common to both ATX and MTX
V6 ATX or MTX NSK Bearing for 4 and 6 rib tensioner pullies (requires installation) (yes, this is the right one, correct width etc) BD20-15DWA 40.06
:thumb:
SHOtimer
#2910
Santa Clarita, Ca
witsimpala said:
Here's your answer.
:thumb:
I would make sure before you order it that it is the correct pulley. Those might be for the timing belt idler pullies.
Doug
