Need opinions on my 3.2
zach44102
BIG TURBO
Georgia
As some must might know i recently spun a rod bearing in my 3.0 which now gives me a reason to swap in my 3.2. My question is should i go ahead and pull the cams out and everything to do valve stem seals. Ill give you a little background on the motor. Its been sitting for 2 1/2 - 3 years..2 or 2 1/2 of those years inside a building outside of the elements. the onther 6 months or so it has been covered up outside in a car port. The motor has a new timing belt, new cam seals, new rb, new mb, new oil pump and 3.0 cams. cams being installed by mark nunnaly the PO. I am aware of the ATF treatment but to my understanding the valve stem seals like to get brittle after sitting for awhile and i am not sure if they could be saved or might not give me problems.
93rev2sev
Hockeytown
If Mark installed the cams, Id bet there were new valve stem seals installed at that time.
It's not a whole lot harder to do valve stem seals with the engine in the car. I'd say run whatcha brung. If the valve stem seals are leaking, you can address them later.
zach44102
BIG TURBO
Georgia
Well mark made the comment to me about the valve stem seals, he said he would reccommend replacing them since its been sitting for so long but i will take you guys advice. thanks guys.
whiteguy3
Scott MacIntire
Silver Spring, MD
You can always do them in the car as others stated. A little bit more annoying, but they may be fine. Sounds like all that motor needs is to be put into a car and run. I'm sure if all else were done water pump and cps were done too. If not, do that with the motor out; it's easier.
zach44102
BIG TURBO
Georgia
I ordered a new waterpump today, picked up new injector o rings but advanced gave me the wrong size o rings. Ordering a UDP soon to go over the new front main i installed today. besides for that i painted the valve covers, timing cover, engine hook, and exhaust manifolds.
shonuffmine
wildchild
sweating balls in fla.pan
Is this the reason why you been blowing up my phone? Put the damn engine in pour 4 qts of ATF in it,put a brick on the gas pedal,start it up n step back n enjoy the fireworks! Damn it son I,m working 12hrs nite shift,if your ass ain,t ablaze don't call me .I dissapoint son
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
LoL.... I like the "if he installed cams he did valve seals" comment.. Unless the valve covers were off the block, or the plugs were pulled out.. then maybe they dried out.. but if they were new they should be fine... I don't think you want that valve stem seal job...
AREA 91
PA SHO SHOP
Area 91
I would change them.
