Need Help
Xlt600Dude
Central Square, New York
I noticed that my power antenna doesnt work... Could that be why my battery goes dead after a few days and also why my radio doesnt play anything?
HoustinoJillian
name's JUSTIN
usa
does the power antenna make any noise? tur nthe key on to the acc setting and turn the raddio on/off... do you hear any whining or clicking fro mthe fender where the antenna comes out?
Xlt600Dude
Im not sure to be honest with you...Im right in the middle of changing my water pump and all that good stuff so when I get it finished Ill let you know.
ohfosho
ontario SHOwner
ontario, canada
there is a connection (round tube, gray in color), under the glove box. most owners have probably unhooked it at some point! (mine is)
Redskull
Badass Mo'fo
New Haven, CT
I would bet it's the other way around. The power antenna control unit is powered by a signal from the amplifier turn-on signal from the radio; if your radio isn't turning on, then it's probably not trying to raise the antenna. of course, anything is possible.
Redskull
Badass Mo'fo
New Haven, CT
the same signal that powers the antenna powers the amp....so if you lose one, you probably lose the other. I would check to make sure the line from the back of the radio has 12v, and that all the wires are hooked up
projectSHO89
SHOless In St L
If you're getting the noise from the RF fenderwell, the motor is probably working just fine, the plastic track is just broken.
There's a writeup in the FAQs at www.shotimes.com on how to replace the antenna mast.
Steve
Xlt600Dude
yes the motor does run...but i figured if i popped in a cd, that the cd player would play it... well it didnt. No sound nothing. The cd wouldnt even eject. But then finally i got it to come out. This car is :nut:
