Need help
SHOtime734
Westlan,Michigan
Alright, so me and "SHOBILL" took apart the sho trying to find where the noise is coming from, we stoped some of the noise which was coming from a pulley. But what we couldnt find was the main noise which happening in the middle below the intake manifold, has anyone ever had a problem like this. i talked to a guy at autozone he said he has owned five gen3 shos and he said it sounds like a buttlerfly valve. if someone could give me some adivice on what this is it would be great. the cams are welded and its has full power its just thay anoying noise.
thanks, Tony
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/umsupWjpnV8&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/umsupWjpnV8&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
jmpSHO
Massachusetts
thanks, Tony
Are the cams welded? If not i wouldn't drive it anymore.:munch:
jmpSHO
Massachusetts
Sounds like a cam is feeling to me. Did you have them welded or did the previous owner?
jmpSHO
Massachusetts
Sounds like it's coming from the front so I would pull the front vavle cover off and check and see what's going on in there.
SHOtime734
Westlan,Michigan
we used a mechanics stethoscope and its not coming from the front its like right in the middle of the intake manifold.
Rubix
I thought you determined in one of your other four of five threads on the same topic that it needed to be shimmed? :shrug:
Is the clicking synonymous with RPMs?
stephen newberg
Ladysmith, BC, Canada
Had the cam sprockets moved prior to welding? I think you have something slapping around. A valve or a piston.
Time to pull the heads, I would think.
pax, smn
nothingtoseehere
Assuming the cams are still fine, I'd still pull the valve covers and be sure a shim did not eject for a bucket.
