Need help with rear exhaust hanger.
zach44102
BIG TURBO
Georgia
I am changing out my rear exhaust hanger that sits behind the driver door and i got the two bolts off that hold the bracket on and the rubber hanger put how do you get the rubber hanger off the braket and the new one on there? It looks like a solid rod through the braket with no way of removing it. Thankyou in advance
kevinspann
Don't take my advice.
Richmond VA
You have a text...
Like I said there, cut the rod out, drill out the ends and replace it with a bolt. Should work.
zach44102
BIG TURBO
Georgia
I fixed it. Cut it drilled it and stuck a rod and nut on it. Thankyou to kevin
kevinspann
Richmond VA
You may have wanted to put a nut on both sides of the bracket to lock it in. Or just tack weld the nut to the bolt so it doesn't back off.
ForcedSHO
Stupid SHO
New Jersey
Lol, i'm trying to replace this one over the weekend. WTF did they do it like this?
zach44102
BIG TURBO
Georgia
Its not that hard to just buy a 5$ rubber hanger and 35 cents for a bolt and nut. Cut it with a sawzall and then drill it out. But then again i didnt know they sold it as a whole for 10$. The hardest part is undoing the 2 bolts because having sfc and limited room its almost impossible to get a wrench up there
ForcedSHO
Stupid SHO
New Jersey
Some BS. Called around and found none at any ford dealership. Ground the end off so that I could pull the rod up. Going to a local auto parts store tomorrow.
143e26w
K4ujdc
15gs2t4
2zs4jyv
zach44102
BIG TURBO
Georgia
Just do what i did. take a sawzall and cut that bar off. then take a drill and drill a hole all the way through and then but a nut washer and bolt on there.
