93whiteonwhite3.2
1993 SHO 3.2 auto stock
So to start I have a 93 3.2 auto all stock that I bought for $450 with 132000 on it and brand new tires couldn't pass it up, but it had been in a fender bender and the core support is pushed back and pinching some wires between the fan shroud and the intake, but I am familiar with the monster these cars and be made out to be. But I have my check engine light on so I did the "goose" test and read the codes. When I read the codes I got 5 different codes; 327: egr feedback signal low, 129: no map or mass air flow sensor change, 167: no throttle position sensor change, 536: brake on/off switch open or shorted to ground, 632: transmission control switch should be cycled once between engine ID and Goose test. Does this ring any bells to anyone? It isn't firing on the first cylinder, I changed the spark plug, wire and I changed the ignition coil. As Nd when I accelerate it will be running rough then will sound like it clears out and sputters a little then takes off like it's supposed to.
