Need help with a weird problem.
ShoStyle
Chaos engineer
CALIFORNIA
I just finished my 92 SHO. (posted pics).
The car runs good, but seems to not wind out the way it should, as if it were running rich.
The check engine light goes on and stays on after a second.
I tried testing with the EEC both the engine off and engine on test and it does nothing. The light stays on and the car does not go into test mode.
Also I get a airbag code 32 light, but I am sure it's unrelated. Maybe.
The mods done are in my signature.
Thanks for any help.
SuperHO
Mental Patient
St. Joe, MI
you sure you're checking the codes correctly? i often get the two slots mixed up and then wonder why my car's not going into self-check mode.
ShoStyle
Chaos engineer
CALIFORNIA
Pretty sure, I will double check the pins. I pulled the procedure from SHOtimes and thought I had it nailed. I will check again, but I am pretty sure I had it right.
SHOmethewayhome
BAD ROLE MODEL
Saint Paul, Minnesota
i had the same problem, i forgot to plug in one connector going to the little black barrel thing with the vacuum line running from the back of the intake into it, and then another line running out there is a small connector and that wasn't letting my butterflies open up. plugged in in and INSTANT POWA!
