OK today i felt like working on my blue turd and come to find out i now have no spark and no fuel pump prime. The only prime i get from the pump is a fart when i first turn it on. I tested for 12v at the inertia switch and i got 6.5 volts. I tested a few prongs on the ccrm plug and got 12v on one or two, and i have 2 good (at least one good)... With both ccrm's i get 6.5v at the inertia switch. If somebody could provide some insight or diagrams of the wiring on the ccrm it would be appreciated.
Im working on testing for spark now so i will update on that issue.
EDIT: I dont know how i fixed it but i plugged my inertia switch back in and hooked up my old ccrm and i now have a full fuel pump prime and 39psi at the rails. Now im still stuck with no spark. I tested for 12v at the coil pack and got 10.5v. So i am suspecting the crank positioning sensor but i allready replaced it and gapped it correctly. But doesnt a chopped up cps or bad cps throw a code? I ran the codes and got 126 and 556.
EDIT part II: disconected the battery the clear the codes and hooked it back up and i have no fuel pump prime anymore, This thing has a mind of its own. Also why would my ccrm click whenever I unplug the DIS?
