vortex2450
Buying Parts...
Long story short while I was replacing the studs in my exhaust manifold I somewhere along the way managed to disconnect or simply forget to reconnect a vacuum line.
I know this because after I buttoned everything I noticed my air only comes from the defrost vents and won't go anywhere else no matter what the setting.
I didn't find any major cause for concern here as defrost was all I needed.
Lately though it must've gotten worse because my SHO stalls at cold starts at least once or twice before it'll run and then it still idles low (~650 rpm).
I know this is a vacuum isue and I can clearly hear the hiss on the fire wall side of the engine but have tried countless times with a water bottle to find it.
SO my question to you guys is where is the vacuum line that runs into the switch for the a/c vents?
all replies are appreciated.
