My SHO
ST 2 SHO
WVA
Well its been almost 5 years.... Yes I still read the forums form time to time. AND yes I still have the SHO.
BUT.
I'am thinking off selling it. Yes it needs work. If ya look back around 2009 you can find the tread on the front bumper install ... I grafted a Ford Focus RS front bumper to the SHO front bumper using parts from both.
I just don't have the time to work on it anymore. Now its now starting.. I believe its a fuel problem. This has happened before and I had to replace the relay box mounted on the front cross bar.
I guess I need help to jump the pins in the box or cable to see if the fuel pump well turn on?
Any help would be great. I'll also think about a good home for it.
This is a 94MTX Green with an RS8 front bumper.
sperold
Last to Know
When you turn the key on.....before you hit start..... the fuel pump will make enough noise that you can hear it in the car, if it is working.
You can also read the fuel pressure at the fuel rail in the engine compartment and is should be near 35 to 40 psi.
That Integrated Relay Control Module (IRCM or CCRM) on the top of the rad, has a relay that needs to close to run the fuel pump, so it is either that or the pump itself (or maybe the trunk mounted shut off switch - Inertia Switch).
Good luck.
ST 2 SHO
WVA
The Inertia Switch has been by passed. I picked up this Integrated Relay Control Module from a user here on the site 5 or 6 years ago. As the first one stopped working.
Witch pins need to be jump to make the fuel pump turn on ...???? The factory service manual I have is very hard to find anything in..... LOL Its the Ford service manual that the tech's at the time had .... Mine is the 1994 manual.
If there another way of jumping it please tell me.
Thanks
