my sho smells burned oil
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
hello guys,
here is another post that i am having some problems with my 92 SHO.. while sometimes when i try to pass the 4k and open the secondaries, i can smell burned oil from the engine bay coming inside and itiching my noise. :eek: .. also it does that when the temperature is getting around 75-80* F and when the engine gets hot too..
dont tell me iam lookig ti replace the valve stem seals, or valve cover gasket + plug seals... :hail:
all advices and replies appreciated..
thanks
endri
yamahaSHO
E85 whore
Arkansas
Are you sure you don't have an oil leak? Vavle stem seals wouls show burned oil out of the exhaust. You're problem is a leak that lets oil out side of the motor.
SHOTYME
Fremont CA
I Know I Have A Baad Leak Only I Cant See From Where. Its Dripping On Top Of The Cat's And Smoking Like A ****! Is This A Common Problem?
40BelowSummer
Puerto Rico
It is not uncommon for the rear valve cover gaskets to leak oil, which will be burned off the cats.
Thats my guess; happened to me.
Endri_SHO
SE 300 , S 500
so what you guys think it might be from the rear valve cover gasket ???
thanks
endri :salute:
Racer X
SHO Pilot, Retired
Connecticut
thanks
endri :salute:
Either that, or the front seals. They can leak on the cats, also.
Endri_SHO
SE 300 , S 500
SHO_Diehard said:
Exactly, which is why you should do the front main seal when doing the CPS.
thanks for replying guys,
SHO_Diehard i already did my 60k in feb 17, 05 9k ago, but i didnt replace cam seals or anything like that, dont tell me i have to get down there again and re do the seals and stuff :hail: ..
oh no not again :nut: :eek: .
thanks :thumb:
endri :salute:
sweet sho
Radium hot springs, B.C.
i just did my CPS and i have an oil leak pretty bad to. I also did my rear valve cover gasket and thought that would fix it but i didn't do the front main seal. I feel like you (no i don't want to take it all apart again :cry: ). I was wondering where is the front seal when your doing the 60K service? I wish someone would have told me. Oh Well
sillystring
Northeast Ohio
Mine is doing the same thing. I made a sort of SHOdiaper out of a piece of scrap leather. (I used to dabble in upholstry)
It catches the oil and has not needed changing in 3 months :thumb:
Endri_SHO
SE 300 , S 500
can you show me a picture how you did it and where did you place that ???
thanks
endri :thumb:
yamahaSHO
E85 whore
Arkansas
I vote for cam seals and/or front main.
sillystring
Northeast Ohio
When I do the head cover gaskets I can snap a pic which will be soon.
I just basically strung a 16"x18" scrap of leather behind the engine under where the head cover is leaking. One side hangs with
(dare i say it?)...bailing wire from the firewall the other hangs from something convienent sticking out of the engine.
(You guy must think I'm some kind of hillbilly now) :nut:
