My SHO seems slow...
Orkin
Arkoma, OK
My SHO just doesn't seem to want to go like it should. It's like I hit about 3500-4000 RPM, and it just doesn't feel like going any further. It will eventually get up there, but it doesn't really pull at all, and I don't feel hardly anything when the secondaries open. Maybe I'm just expecting too much, but my mom's '04 Impala (base model) pulls harder than my SHO!
Here's what I've done since I got the car about 18 months ago:
  • Crank position sensor
  • Water pump
  • Spark plugs
  • Spark plug wires
  • Valve lash adjustment
  • Crank seal
  • Cam seals (although one's leaking again already)
  • Timing belt
  • Timing belt tensioner
  • Accessory belt
  • Oxygen sensors
  • DPFE sensor
  • Intake manifold gaskets
  • Intake manifold hoses
  • Fuel pump
  • Catalytic converters
  • Mufflers
  • Thermostat
  • IAB valve
  • Rebuilt transmission
  • Fuel filter (twice)
  • Air filter (twice)
  • Castrol GTX every 3,000 miles
As you can see, I've treated the car right. The only problems I have engine-wise are a 332 code (it's gotta be the EGR valve this time), and my alternater doesn't "come on" until I get it up to 3,000RPM (strange, but true).
I thought maybe my exhaust was still clogged from when my old cats broke apart, so I disconnected my exhaust from the y-pipe back today and took it for a test drive. It actually seemed even slower, and idle was weak...(it sounded awesome though, especially at idle...just WAY too loud).
Does anyone have any suggestions?
BenBrausen
Minneapolis, MN USA
Check the MAF sensor. For a lil bit my car felt really slow gettin up there and at 80mph it hit a brick wall and wouldn't go any faster. MAF sensor had crap on it from the K&N filter oil.
Redline
Fire It Up
Sandpoint
I agree. I clean mine periodically as well, because I have a K&N air filter. It has definetly made a significant difference in performance for me
RJ-92
Crappy NYS
Take off the MAF and hit the hot wire with some brake cleaner, and some clean, compresed air a few times. I woulkd lose the K&N BTW, not worth the trouble with the oil hurting performance.
Orkin
Arkoma, OK
I stopped at AutoZone this morning and picked up a can of $5 electric contact cleaner. Sprayed down the thing for a couple minutes, and reassembled. It seems to have helped alot! I took the "long way" to work this morning, where I could do some testing without risking a ticket. No more getting to 80 and hitting a wall, now it just keeps going like I'm still at 40! I only took it up to 100, but there's a definite improvement.
Thanks guys, I never thought of the MAF. I would've replaced the whole engine before I got to that thing!
Orkin
shoteen95
isn't a teen :D
Dearborn Heights, MI
wow, nice to see such a happy result from a good cleaning of a dirty MAF...
hmm..
come to think of it, i have a K&N...i should give it a good cleaning tomorrow and see if it helps..if i notice a change, i'm boycotting K&N filters...
stangeater
Farm Boy
Let the oil dry on your filter a little before you put it back in and drive.....just like it says in the instructions. :nut: No need to boycott K&N. By the way, won't brake cleaner ruin your MAF? A mechanic told me to never use that to clean the MAF.?????
oh_SHO
Ohio
I have a good experience cleaning mine too. K&N plus and previous owner that was oil happy equaled one dirty MAF. I had to wipe the oil out of the airbox from the K&N. Glad to hear that it worked out well.
Redline
Fire It Up
Sandpoint
Not sure, but considering that it is such a sensitive sensor, I only use electrical cleaner on it, dont want to damage that baby!
windsormw
stretch nuts
windsor , ontario
I agree with red line
anything electrical i recommend LPS " no flash " ........non-flamable/aclohol contact cleaner .
Or just regular carb cleaner will work
