tery
Silvia survived the purge- summer car
Alright, so I went to the welder on Friday and he says he can put the frame to rights for between 3 and 600 bucks. I'm certainly going to do it cause the rest of the car is so good.
I thought there were two missing pieces of plastic molding on the drivers side and found them in the trunk. yippie! I took out the MAF and it was real dirty. Cleaned it well and so far I get no more stalling. We'll see over the next few days if it stays fixed. So..serpentine belt, rear brakes RF outer tie rod and...ouch... LF wheel bearing and lower ball. I should be soaring through town after all this. its only got 126k on it. I will need to do something about the hood at some point and there is a plastic cowl type piece that runs across the whole from behind the radiator that the headlights connect to. It is broken off on the passenger side, I suppose a casualty of the deer hit that crunched the hood a bit too.
Can the hood just be ...pressed or flattened back out, or does it need to be replaced? Have to talk to the body shop guy I suppose.
happy days ahead!,
Terry
happy days ahead!,
Terry
